Thread: daikin split fault code E6
26-03-2014, 01:06 AM #1
I have a daikin Caset R407, unit was showing a fault code E6 a month a go. Replaced the outdoor unit,new unit was working OK for 1 month, today E6 it come back.can any one help pleas.
26-03-2014, 07:21 AM #2
Re: daikin split fault code E6
E6 as you probably know means compressor lock.
Why did you replace the outdoor unit?
Have you checked your incoming mains voltage is correct?The difference between genius and stupidity is that genius has its limits.
Marc
26-03-2014, 01:24 PM #3
26-03-2014, 01:35 PM #4
Maybe he used a scrapper from elsewhere!
Bedford. Now retired and trying to relax.
27-03-2014, 09:01 AM #5
hi, E6:Outdoor compressor start up error.
read more..
