Thread: R404a
    Mar 2014
    vietnam
    45
    3
    R404a
    hello everyone
    Im usually install cold room using R404a refrigerant but i haven't document related pressure and temperature R404a. Hope everyone to help!
    Thanks,
    May 2012
    59
    1,528
    36
    Re: R404a
    Mar 2014
    vietnam
    45
    3
    Re: R404a
    Thank Rob White
    regards,
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: R404a
    Just curious....On your second picture, are these condensing units mounted far enough away from the wall for adequate air flow? And..your HP/LP switch could be located on the base plate as vibration up high, as you have it currently on the plastic electrical box, may cause premature mechanical failure.
    Thanks for posting pictures.
    Jun 2014
    yunlin
    38
    Re: R404a
    if you have smart phone
    you can down load an app
    search : KoolApp - ref. slider
    this app was produce from Danfoss
