    Dec 2005
    Working out energy consumption
    Hello,
    My client has some really old banger of a chiller that every year needs so many thousand pounds worth of work done to it. Components keeps failing, faults keep getting thrown up, and there has been arguably no maintenance carried out on it (inside where the coils and heat exchanger are it looks like beetlejuices house).
    Basically, our client is pretty stubborn, and all engineer recommendations seem to get ignored, so I'm looking to put together a report, detailing the energy consumption of the current chiller, compared with the new energy efficient bad boys that are available.
    ....so how do I do it......all the nameplate stickers on the chiller are long gone. I'm assuming I would need to look into the electricity (in. kW) both compressors and all the fan motors consume, compare that with the cooling capacity of the chiller, and there I have my efficiency ratio.....then compare to new chillers. Then I can turn all this consumed energy into financial figures by looking at the local energy tarrifs. yay/nay?
    Any help would be great guys
    Cheers,
    Halfcan.
    May 2012
    1,247
    28
    Re: Working out energy consumption
    There are data logging devices that you can fit to measure
    all the things you suggest but they cost and if this is just
    a one off then it would not be cost effective.
    Something like this.
    http://www.businessedgeltd.co.uk/products/climacheck/
    The only other way is the hard way, add it all up and do the maths
    but don't be too surprised if the customer still stubbornly refuses
    to listen.
    Sometimes there's no telling some people. So if you do this, will you
    be charging him for your efforts because you might put a week of work
    into it only for him to ignore you?
    Rob
    Apr 2014
    United Kingdom
    1
    if it is any use, I own and use a portable ClimaCheck and have done for around 4 years. I have carried out multiple remote assessments and can offer some advice about the ClimaCheck if required. We also have around 20 chillers with fixed climachecks running which we monitor remotely.
    Tony
    Oct 2008
    newbury
    56
    1,351
    29
    Quote Originally Posted by Anthony Wootton View Post
    Tony
    hi Tony
    Good to see you here
