Thread: I am freezing
14-03-2014, 02:57 AM #1
I am freezing
Currently i am sitting in my apartment and the aircon is controlled centrally.
Currently it is stuck on 21 Degrees C and its bitterly cold. Unfortunately if i turn it off there is absolutely no air circulation and the room turns into an oven. I managed to access the settings/service menu by holding down the TEST button for longer than 4 seconds but what i need to know is how to remove my self from the group settings and be able to control my temp individually
The unit on the wall is a daikin wired remote with the model number
BRC1D61
any help would be appreciated!!
14-03-2014, 08:23 AM #2
Re: I am freezing
If you remove the Group settings you will fault the whole system.
If the Air Con is controlled centrally then I would suspect it has either a centralised controller or iTouch controller fitted. This higher command controller will always override any settings you put in your BRC1D.
The only real solution is to complain to whoever has control of the Master controller and request that your unit has the temperature setpoint raised, or they allow you to have temperature adjustment settings via the BRC1D.
14-03-2014, 10:06 AM #3
Re: I am freezing
This won't help you in the slightest and I'm just
wondering aloud now but it's funny that in the
summer 21 degC is ok but in winter 21 degC
seems cold. Funny people us humans? Not just
you, all of us. When it's hot we set the AC to
21 and we love it, when its cold we set the AC
to 24 degC, 25 degC or even higher and we still
moan it's cold. Might be a humidity thing?
Rob
.Last edited by Rob White; 15-03-2014 at 12:53 AM.
14-03-2014, 05:53 PM #4
Re: I am freezing
Because we're British and like to moan
