    May 2010
    bridgend
    10
    Unhappy Charging a Mitzi City multi
    Hi there, looking for some advice I'm working on a Mitzi City multi and am now trying to charge with additional refrigerant, I need to add 60kg to the factory charge, but the problem is I've added 42kg and can't seem to add any more, any suggestions as to how to add the remaining charge.
    manchester
    5,639
    Re: Charging a Mitzi City multi
    thats a lot of additional charge- is the pipe calculation correct?- if it is, get a 20k bottle of gas and charge it via ur reclaim rig whilst the unit is running in cooling mode
    That is, as stated above, one heck of an extra charge.
    Have you double checked the room leakage safety factors as well?
    manchester
    5,639
    think the condensers sited in cardiff-33 miles along the m4
    Mar 2006
    Lancashire
    1,859
    28
    As install monkey says, use your reclaim machine to push it in or close the liquid line (pump down) and the suction pressure should drop enough for you to be able to get more in.
    Marc
    Oct 2012
    Russia
    42
    392
    Its wrong answer)))
    Try like that
