Thread: R134a
19-03-2006, 11:44 PM #1
R134a
Hello
I have a small cooling system with a display case and 3 small storage cabinets, its charged with R134a and has a LŽunite hermetique compressor.
What is the ideal suction and discharge pressure for the R134a?
it has a water cooled condenser.
I have been told to run it at about 1 bar lp and 8 bar hp, is that correct?
HSH
20-03-2006, 02:33 PM #2
Re: R134a
Condensing pressure depends on water temperature, and evaporating temperature depends on case setpoint.
20-03-2006, 08:24 PM #3
Re: R134a
does not sound far out though,high pressure sides a bit low is it over condensing,ie too much water, is the liquid line too cold, mind you if its working o/k who cares !
10-04-2006, 08:17 AM #4
Re: R134a
Sounds good. Low head pressures are always a good thing.
When you say bar. are you talking gauge pessures or absolute????????????
I'm guessing gauge or you have a dam good compressor.
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 12:44 AM -
R12 to R134a
By fireblade in forum DomesticReplies: 15Last Post: 19-08-2006, 09:02 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 09:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 09:59 PM -
R507 in an R134a compressor: system design
By DaBit in forum Technical SpeculationsReplies: 17Last Post: 01-05-2003, 09:25 AM
