Thread: U V W terms
05-03-2014, 08:09 PM #1
U V W terms
how r u guys
i found these terms on the compressor terminal cover (U V W) beside
the S Start R Runing C Common terms
what are their meaning
05-03-2014, 08:13 PM #2
Re: U V W terms
Not sure about on a single phase motor but with three phase they are just the standard terms used for them.
Line 1 U (Red)
Line 2 V (Yellow)
Line 3 W (Blue)
If used correctly from the power station down to the motor maker then the motor rotation will be correct every time it is wired in.Brian - Newton Abbot, Devon, UK
05-03-2014, 08:17 PM #3
Re: U V W terms
universal compressor cover for a single phase compressor and a 3 phase compressor
to identify the terminals
05-03-2014, 08:18 PM #4
Re: U V W terms
Uvw are the designations for the windings in a three phase motor, this compressor maker probably uses the same shell for single phase or three phase
05-03-2014, 08:20 PM #5
Re: U V W terms
Ha ha ,you guys think and type fast
05-03-2014, 08:58 PM #6
