Thread: sabroe smc 16-100
05-03-2014, 07:39 PM #1
sabroe smc 16-100
hello gentlemen. I want to install the motor compressor
a variable speed controller (vsc) know that the model is very old. I would like your opinion and your experience in similar cases
Thanks a lot.
Αναίρεση τροποποιήσεων
Cancel
10-03-2014, 01:18 AM #2
Re: sabroe smc 16-100
hello Dim.
personally I would not apply a VSD, as there is a minimum speed requirement for oil pump and suitable lubrication. The compressor is energy efficient at a fixed speed and utilize the cylinder unloaders for capacity regulation.
Just my preference others may have alternative opinions
10-03-2014, 09:44 AM #3
Also to add to Magoos post.
On certain compressors the flanks are held together by centrifugal force and if slowed down too much, the flanks tend to seperate. Obviously catastrophic for the compressor.Last edited by marc5180; 10-03-2014 at 10:00 AM.
Marc
20-03-2014, 05:10 AM #4
- Join Date
- Sep 2009
- Location
- Iran
- Age
- 66
- Posts
- 672
- Blog Entries
- 1
- Rep Power
- 19
minimum speed for SMC 16-100 is 700 rpm and max. is 1500 but you should look for sabroe books and find right min/max speed in different evaporator /condenser temperature also it is different if you have water or air cooled covers
