05-03-2014, 01:19 PM #1
Refrigeration based industrial cooling
This is probably a silly question.
I currently have a battery of cooling towers, with a cooling capacity of about 4500kW
Is it totally ridiculous to consider a refrigerant based setup?
I have looked at adiabatic and air blast coolers, but the foor space they take up is massive, and struggle to achieve the temperature of about 24c during the warmer months
Thanks in advance
05-03-2014, 02:47 PM #2
Re: Refrigeration based industrial cooling
Refrigeration would do that very easily.
specifics, design, location, application all vary but
refrigeration was invented to do that very thing
Remove heat.
Rob
05-03-2014, 03:55 PM #3
air cooled will track DB temp water cooled tracks WB that and the higher efficiency of water means they are hard to beat. the downsides are as you already know.
