Results 1 to 2 of 2
    Mar 2014
    Ecuador
    35
    1
    Question Help with Mayekawa MYPRO CP IV Registers
    Hello everyone!
    I'm having a little issue with a screw compressor MYPRO CP IV. I've read the entire manual but I haven't found a register that allows to write via communication the desired Suction Pressure Setpoint. Does anybody who have worked with this compressor, if this is possible to do? If not, how can I give the compressor this setpoint?
    Thanks a lot for your help!
    Henry
    3,355
    Re: Help with Mayekawa MYPRO CP IV Registers
    http://www.mayekawausa.com/techdata/index.html
    Henry,
    I have no experience with these but go to this link & at bottom is Mypro CPIV.
    on pages 38 to 41 is what I think you are looking for, CONTROL PRESSURE.
    Section 4.4 page 51,52 refer to remote capacity control.
    You would have to check if you have that option as well as relevant passwords if needed.
    If no luck suggest contact your nearest Mycom representative for guidance
    Hope this helps
Tags for this Thread
