Results 1 to 19 of 19
    Feb 2014
    libya
    48
    11
    Angry propane screw compressore failur (HOWDEN)
    Good day all,
    I am working in a gas plant. our issue is with propane screw compressor package, we are suffering a lot from the damaging of the seal due to oil continamated with vapor water or some thing else. The colure of the oil changed to the milky oil and also the consumption of oil is too high>is any one could help us.
    many thanks
    3,357
    Re: propane screw compressore failur (HOWDEN)
    Mustafa,
    Maybe you need to check oil with oil analysis & find out what contamination is.
    When you find out what it is check where contamination could come from, then go from there.
    Excessive oil consumption could be damaged coalescers in oil separator, or loose. Replace/tighten.
    Also liquid propane entering compressor could also wash oil out.
    Feb 2014
    libya
    48
    11
    Dear Ranger,
    I have got a failure report with pics, where could I passed to you if you donot mind?
    3,357
    Mustafa,
    View profile, about me, then download v card
    Feb 2014
    libya
    48
    11
    Dear Richard,
    I have sent you an e mail, have you received??
    3,357
    Quote Originally Posted by mustafa2014 View Post
    Dear Richard,
    Yes have sent reply
    Feb 2014
    libya
    48
    11
    dear Richard,
    sorry for bothering you.
    I have not receive your mail. please send it agine to (Mustafa.alhur@gmail.com)
    3,357
    dear Richard,
    Mustara, I sent again so let me know if you receive it.
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, mustafa2014
    welcome to RE forums...
    Good day all,
    many thanks
    can you give us some more info ...
    Your package is ... closed circuit to cool down some other process gas or propane liquefying plant,
    is it one stage plant with economizer or two stages
    suction pressure ...condensing pressure ...
    is it used for boil off gas, cooling also some butane ...
    type of oil cooler ... temperature of oil entering compressor ... discharge oil temperature
    how old is your plant ... what maintenance you did on plant ...
    Please, write down all what you think can help us to troubleshoot your plant ...it is not an easy job to do remotely ...we need as much as possible data regarding your plant ...
    Best regards, Josip
    Feb 2014
    libya
    48
    11
    Dear RANGER1,
    I have received you mail thank you very much. I am preparing full information package for you right know.
    Dear Josip,
    Find below our reply:-
    our package is a propane refrigeration package (three identical trains). Each package is designed to deliver 3592 KW of refrigeration at -36C.The propane package is installed in the GAS HC DEWPOINT CONTROL UNITE.
    2-one stage plant with economizer (I HAVE dwg for all the train if you need).
    3- type of oil cooler>>tube and shell cooler by water
    4-delta p of oil at starting is 5 bar after warm reaches 3 bar
    5- our plant life just 9 years.
    the problem is commen for all trains
    I will send you the rest of information after 2 houres
    many thanks
    3,357
    Mustafa, compressor. Model number would also be helpful WRV or WRVH ...........
    Feb 2014
    libya
    48
    11
    dears,
    please Ringer1 & I have sent to only some oil failure reports, we still have the same failure up to know.Josip I would like to send you some PICS & data sheet in order to compare with the actual data, but I could not up loaded here, please advice how can I up loaded ,so you can have complete picture.there is quit different between design data and actual data
    These are the information
    Model:- WCVTN/510
    temp. of oil= about 60c.
    sorry about delta P of oil it is=4.3
    gas section temp.=-13
    gas disch. temp=81
    seal type=John crane 279/part Nr.N0579108040
    elastomers are used in shaft seal & compressor= Viton / PTFE
    coupling is installed on compressor/drive motor=METASTREAM TLKS-2000.
    moreover, HAVE ASKED TO DO A COMPLETE TEST FOR OIL AND GAS.
    the oil has been changed many times
    Feb 2014
    libya
    48
    11
    Dear Ringer1,
    I have sent to you some pics , but I think you mail box is full
    Feb 2014
    libya
    48
    11
    Mechanical seal, type 270, 6.5", repair & parts for tag no. Tor-k13972rba
    3,357
    Mustafa, please try again.
    Feb 2014
    libya
    48
    11
    Dear I have sent to you please check your mail.
    Feb 2014
    libya
    48
    11
    Dear Ringer
    is there any up data to my case, please advice?
    I tried to send pics once more but your server rejected the mail with pics.
    have you got any other mail??
    BR
    3,357
    [QUOTE=mustafa2014;293278]Dear Ringer
    Mustafa please check your email for different address just sent.
  19. #19
    Feb 2014
    libya
    48
    11
    Dear Ringer1,
    I have just send to you pics. please confirm
    thanks alot
