Thread: Daikin f3
    Jan 2009
    scotland
    9
    Daikin f3
    Was on a site today to look at a vrv reyq14p8y1b. Set up service checker and will return latter.[ have to finish another job first] unit was on heating at time and discharge was reaching 110 to 125 dec. hp was at 22 bar/25 bar and compressor not reaching full speed. My gut says to reclaim charge and check for low refrigerant or non-Cond's.
    Oct 2007
    manchester
    5,639
    45
    Re: Daikin f3
    check resistance of discharge sensor- could be cooked, had it before where the sensor plugs on the pcb vibrated 1/2 way out
    Jan 2009
    scotland
    9
    Re: Daikin f3
    I wish it was the sensor but have checked all thermistors and reading correct
    Oct 2012
    Russia
    42
    392
    Re: Daikin f3
    SH? Evap press, bypass and injection on/off?
    High discharge in Daikin -> dead oil.
    Oct 2001
    Nottingham UK
    5,668
    Re: Daikin f3
    Follow the troubleshooting guide for high discharge temperature...attached below
    Attached Files Attached Files
    Oct 2013
    Turkey
    33
    15
    hi, outdoor abnormal discharge pipe temperature.
    daikin fault codes
    Mar 2014
    32
    Re: Daikin f3
    Quote Originally Posted by richard.. View Post
    Low head pressure and high discharge, probably low refrigerant. Was the checker in discharge drooping control?
