Thread: Back Pressure Valve
18-03-2006, 08:37 AM #1
Back Pressure Valve
Hi all,
Somebody has idea the application of back pressure valve (ex. PM3 of danfoss)?
Is this applicable on glycol system?
18-03-2006, 09:04 AM #2
Re: Back Pressure Valve
Hi Guapo
The Danfoss PM3 is a modular valve, the PM3 is a 3 Port main valve with room for 3 pilot valves. PM valves are now being replaced by Danfoss, with the ICV range, same pilots, but an improved main valve, better part load performance, less bounch open - closed due to the v ports in the barrel around the gas entry point.
I have used the PM3 on evaporators as pressure regulators to stop fluid freezing, or as crankcase pressure regulators to stop compressor overloading on hot start-ups
Kind Regards. Andy.
18-03-2006, 04:38 PM #3
My first question is... why is the back-pressure regulator being added?
It will certainly work on a glycol chiller or water chiller for that matter.
If the valve is being added to keep the evaporating temperature of the chiller at a higher pressure to prevent freezing, I suggest you might have other problems that should be investigated.
back pressure valve in chiller
By vinod in forum Air ConditioningReplies: 2Last Post: 12-06-2006, 06:29 PM -
Compressor back pressure rating
By Cary in forum FundamentalsReplies: 9Last Post: 05-12-2004, 08:42 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
Low back pressure compressor application
By Abe in forum Technical DiscussionsReplies: 5Last Post: 31-07-2001, 11:43 PM
