Thread: Mitsubishi MNET Cable Advice
24-02-2014, 11:09 AM #1
Hi Everyone,
I am in need of some advice in regards to connecting Mitsubishi MNET to a Cool Automation Cool Master for external control via a Lighting Control system.
Link for Cool Automation Box - http://coolautomation.com/products/c...-electric-vrf/
To cut a long story short - I do not know what is the correct type of cable to use for MNET. Basically I am going to piggyback an AG150A.
Everywhere I have been reading is contridicting on what type of cable to use. If my research is correct this cable should be acceptable but I am unsure.
http://australia.rs-online.com/web/p...cable/7492576/
I was hoping that someone could confirm that the cable I have suggested is appropriate or post a link to an appropriate cable.
25-03-2014, 02:55 AM #2
Re: Mitsubishi MNET Cable Advice
Mitsubishi Electric Mnet required shielded/screen cable.
1.25 mm2 shielded cable CVVS, CPEVS, MVVS are recommended.
Braided type or foil type is Okay to use.
However make sure to have single point grounding in Mnet to avoid noises.
