    Feb 2014
    Davis, CA
    2
    Question Pedal powered compressor
    Hi all,
    I'm not an expert on this topic but I have an idea for a hobby project that I hoped I could get some feedback on here.
    I'm interested in trying to make a pedal-powered ice-cream-and-frozen-drink maker that runs a compressor directly. I'd like to know the feasibility of this. Some back-of the envelope calculations:
    - A typical biker can put out about 200 watts (~1/4 hp) continuously
    - I'd be aiming to cool about 1 quart of liquid from room temperature to frozen. Given the specific heat and heat of fusion of water, this amounts to change of energy of 120 Watt-hours.
    - If the coefficient of performance of the system is 2, then one should be able to cool the liquid in about 20 minutes (120 W-h/ (2* 200 W)).
    So this seems theoretically possible, but one would need a compressor and refrigerant system that fits the bill. It would have to be a compressor that could be efficient when run by an external belt/crank giving about 1/4 HP. One can use gearing to increase RPM, but it would be best if the RPM required were < 2000 RPM. And the refrigerant should evaporate at a below-freezing temperature.
    Main questions:
    - I'm sure I'm missing some major considerations - what are they?
    - What compressor would fit this bill? I thought that maybe something designed for A/C of compact car might do. As far as I can tell, all compressors designed for small fridges (or countertop ice cream machines) are hermetically sealed combined motor/compressor units.
    - What refrigerant would make sense? If this could be done with propane, it would make the DIY aspect easier.
    Thanks for your help!
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: Pedal powered compressor
    "Legging it" has taken on a new meaning in this post.
    If i had to provide stable cooling in your situation, i would use a 300 Amp/Hour battery to power a Danfoss 12/24 DC compressor and top up the battery by leg power.... driving an old 35 amp vehicle alternator.
    That way you can take a break to catch your breath.
    11,025
    Don't forget that you also need to power a condenser as well.
    Feb 2014
    Davis, CA
    2
    Could the condenser be passive? That is, just a set of coils that the refrigerant passes through with a lot of surface area? I suppose a small mechanical fan blowing air over the coils would boost the efficiency a lot without a lot of additional effort for the biker.
