    Mar 2006
    Lakeland
    9
    Lightbulb Pressure/Temperature relationship
    I have a question in regaurds to pressure/temperature relationship. We all know that when it comes to Sensible Heat, pressure and temperature are directly perportional as pressure rises the boiling temperature or saturation temperature also rises. And when it comes to Latent Heat pressure and temperature are indirectly perportional. As pressure rises latent heat of vaporization per Lb. falls. until a substance or refrigerant reaches its critical pressure. But my question is does the specific heat value of a substance change with pressure and if so how and in what way????
    Feb 2001
    Tampa Florida
    1,076
    Re: Pressure/Temperature relationship
    I would think that specific heat increases with pressure as a result of increased density.
    Jun 2001
    N.Ireland
    1,630
    Hi Latent Heat
    Look under the Forum section that shows the software downloads for a program Ref Utilities, you can model this with all sort of refrigerants using this program
    I have not checked what the sensible heat capacity does with pressure, but I would assume density is the deciding factor.
    Kind Regards Andy.
    Mar 2006
    Lakeland
    9
    Thanks Andy, as far as sensible heat goes we know it is directly proportional with pressure. The thing iam concerned with is the specific heat value and after looking into it from what I have found it looks like the specific heat value follows the same rules as sensible heat and opposite of latent heat.
    Jun 2005
    S****horpe
    135
    Perhaps this is a misunderstanding of terms? Specific heat capacity is the amount of energy (Joules) per weight (kilo) to give a temperature rise (degrees C). This is the same as sensible heat, i.e. energy in, temp goes up.
    It's a lovely day to pump some gas
    Jun 2001
    N.Ireland
    1,630
    Quote Originally Posted by Johnny Rod
    Specific heat is the correct term. Sensible is a heat capacity of a product.
    Kind Regards. Andy
  1. Replies: 6
    Last Post: 18-11-2005, 04:30 PM
