    Jan 2009
    Scotland
    79
    daiken parts for panansonic
    Hi all,
    I need an internal board for a Panasonic twin split. Cassette model CS-W24BB4P. Unfortunately it is obsolete. Does anyone know if there is a daiken board which would be suitable?
    manchester
    5,639
    Re: daiken parts for panansonic
    daikin panasonic kit was only interchangable on the skyair (daikin) and the urban range(panasonic) as they were both manufactured by matsus.h,i,t,a (anti swear filter stops me typing it)
    have u tried getting the pcb repaired?
    Jan 2009
    Scotland
    79
    No I haven't, who do you suggest to repair it? Problem is fan won't run on slave unit, not getting a supply, swapped the boards and fan runs.
    manchester
    5,639
    http://www.techcentre.co.uk/repairs/...-circuit-board
    before you do- check the relay for the fan is switching- could be pitted contacts- you can get pcb relays from RS components-for a few quid
    Jan 2009
    Scotland
    79
    Cheers install, much appreciated. Is there anything else you can think of that I could be missing?
    manchester
    5,639
    there should be a power relay too that will switch the unit on- might be worth checking, also look for cracked soldered joints
