Hybrid View
14-02-2014, 01:36 PM #1
Fujitsu ASAA09JGC / AOAR09JGC Error
First of all, I am very glad that I can joint with this forum, it's my pleasure can joint with it.
Dear all, I have some problem with my air conditioner :
Fujitsu Single Inverter - ASAA09JGC (Indoor) / AOAR09JGC (Outdoor)
and the problem is Outdoor Unit don't want to run as well as supposed to be, it's running only about 10 seconds and then stops, but the Indoor unit still running like usually. Even I've set the remote to 18 degree's Celcius with Cool mode.
Then the indicator Led's flashes :
Operation(Green) Timer (Red)
Flashing Flashing ------------ together
Flashing OFF
Flashing OFF
Flashing OFF
Flashing OFF
Is there anyone can help me how to repair this error???? because I don't have "Service Manual" for this unit.....
Thank's
14-02-2014, 06:50 PM #2
Re: Fujitsu ASAA09JGC / AOAR09JGC Error
I'm not sure that you rightly counted flashing. Look at manual
http://www.mediafire.com/view/15b8tq...%2007_TROU.pdf
and
https://www.mediafire.com/view/8lik6...0ASAA09JGC.pdf
14-02-2014, 10:45 PM #3
Okay, I will check again.......
Thank's a lot for your information.
15-02-2014, 08:51 AM #4
Can't find your exact model but that pattern indicates "Outdoor unit main PCB error" hope this helps
