    Nov 2013
    10
    Question TXV or some kind of adjustable valve for high temp/pressure VAPOR R134a?
    We are simulating an organic rankine cycle on a small scale, but we are unable to find a tiny expander for work output (opposite of compressor work input). At this scale, we are mostly just testing a heat exchanger for the generator (evap) so we plan on putting in an expansion valve between the generator (evap) and the condenser.
    The only problem is that since the cycle is running "backward" with a liquid refrigerant pump (in lieu of a vapor compressor), after the generator (evap) the refrigerant would normally be going to the turbine/expander but instead we need a way to expand vapor 400psia @ 239degF to 154psia @ 195degF (constant enthalpy) doing no work. In this dummy cycle, the only work being done is on the heat exchangers. Could I just use some kind of needle valve to dial in the pressure drop?
    May 2013
    Europe
    13
    Re: TXV or some kind of adjustable valve for high temp/pressure VAPOR R134a?
    What is the proposed performance of the turbine for you cycle?
    Nov 2013
    10
    Quote Originally Posted by Aurel STDL View Post
    For this cycle, none. This is just a dummy cycle to test our heat exchanger as a condenser and evaporator with no output of performance. In the next scale the system will actually have output of about 50KW. I just need to expand the gas to a low pressure/temperature for the condenser. If this was plotted on a PH diagram, it would be a rectangle (instead of a Star Wars Sandcrawler shape) with the flow going clockwise.
    May 2013
    Europe
    13
    It is an interesting concept to test an heatexchangers for ORC. Here is a design of an microscale ORC concept with outflow turbine. https://grabcad.com/library/oracon-o...ycle-concept-1
    Nov 2013
    10
    So can I just use a needle valve or a gas pressure regulator?
    Auckland
    74
    3,357
    37
    A swageloc needle control regulator will handle the high pressures.
    Nov 2013
    10
    Great. I'll try it. Thanks for you help!
Tags for this Thread
