    Jan 2014
    Ireland
    3
    Plunge pool heat exchanger
    My first post...
    I've installed a nickel brazed plate heat exchanger for chilling pool water that's treated with sodium hypochlorite...Although it should withstand the treatment. .. it has developed a leak after only a few weeks of use. .. I'm trying to source a titanium BPHE but finding it very difficult, has anyone any expertise in this field, will a titanium one do the job and what are my options.. Thanks cond.
    manchester
    5,639
    Re: Plunge pool heat exchanger
    http://www.ukpoolstore.co.uk/acatalo...Exchanger.html
    found this- make sure u specify bronze ends
    Jan 2014
    Ireland
    3
    I should point out I'm using refrigerant on the secondary side, is the above suitable for refrigerants?
    manchester
    5,639
    probably not- my bad,
    calorex us condenser heat to warm up pool water- hrp do a coil thats suitable for pool water and fridge gas
