    Feb 2014
    Serbia
    1
    ammonia heating system
    Hello.
    I have just recently learned about ammonia refrigerator where you input heat and get low temperature without using a compressor. I don't know enough to even guess if an idea of mine could work, so i thought I might ask experts. I don't even think that I could come up with a patent, so I'm just interested if it was possible.
    The way I see it, for an ammonia refrigerator to work, one needs to provide high temperature to start the process, lower temperature to cool of the ammonia and as a result get very low temperature. I wonder if it would be possible to build a system, without using a compressor, to which one would input very low temperature ( around 0 degrees Celsius or lower) , higher temp. ( 5 to 15 degrees Celsius like temperature of the ground about one meter deep) and as a result get high temperature which could heat a house. With such a system, the colder it gets outside, one could get more heat to warm up.
    11,024
    Re: ammonia heating system
    Nope.
    You do not 'add' cold to a system you actually moving heat.
    3,362
    Maybe you are referring to absorption refrigeration?
    Apr 2008
    Canada
    253
    4
    21
    It does sound like absorption refrigeration.
    Here's some reading material
    http://users.ntua.gr/rogdemma/A%20Re...chnologies.pdf
