    Jul 2012
    romania
    Bitzer oil pressure
    Could someone explain the role of the Internal Oil Pressure Regulating
    Valve , thank you .
    May 2012
    59
    1,528
    Re: Bitzer oil pressure
    http://www.bitzer.de/eng/products/docu/doc_det/5
    Compressors with oil pumps need to have oil pressure higher than
    the crank case pressure, but not too high as to cause damage to seals
    and such.
    The oil pressure is regulated by the Oil Pressure Regulating Valve and it
    dumps excess oil back into the crank case.
    Rob
