    Feb 2014
    indonesia
    11
    high suction pressure
    Hello,
    I'm doing commisioining duct-split unit (DX system),
    detailed outdoor-unit with a scroll compressor copeland ZR72KC-TFD (I max 12A)
    R407C charge, indoor-unit with cooling coil capacity 14.3kw with danfoss expansion
    TGEX-6TR-20kw (P.N.067N2236)
    T room control setting at 24C.
    after vacuumizing and charging R407C, start-up and running the unit,
    after 12 hours running,
    T room is still too high at 25-27C
    Suction pressure = 80PSiG and liquid pressure = 270 PSiG
    the compressor I run = 8 Ampere
    what's about wrong with this unit??
    I'm confused why the suction pressure can be high (80 psig)
    My last bit of waste refrigerant (from liquid line), and then
    pressure turns into P suct = 80PsiG P liquid = 255 psig
    Please opinion or input to have experienced the above case.
    Apr 2001
    79
    5,071
    35
    Re: high suction pressure
    Evaporator air in temperature = ?
    Evaporator air out temperature = ?
    Low side saturation temperature = ?
    Suction line temperature = ?
    Condenser air in temperature = ?
    Condenser air out temperature = ?
    High side saturation temperature = ?
    Liquid line temperature = ?
    11,025
    High load on system or unit undersized plus we need all the information that Gary detailed.
    Feb 2014
    indonesia
    11
    Garry and Brian,
    Noted.
    Thank you for the advice
    Aug 2010
    77
    Quote Originally Posted by apandi View Post
    Hello,
    A suction pressure of 80 psi isn't unremarkable with an air on of 27C? Set the head pressure controller to maintain 265 psi and add gas until the liquid line measure about 35 C, this will give you 9K subcooling and you shouldn't be far wrong at this point. When the room temp gets to 22 then check your superheat and adjust as required. 4 - 10 will probably be ok for most applications?
    This is the best I can come up with with the info at hand?
    Auckland
    74
    3,357
    37
    Did you liquid charge the system.
