Results 1 to 2 of 2
    Feb 2014
    66
    1
    Wink Heat Pump Fan Not Turning
    Dear Forum,
    My heat pump fan does not spin. If I turn it off and try to spin it, it turns freely, but with it powered up, it turns tight. The cap seems to be OK; no bulges.
    Is my motor shot?
    Thanks!
    Mike
    Read more: http://www.doityourself.com/forum/he...#ixzz2sJEvt5k0
    Apr 2008
    Canada
    253
    4
    21
    Re: Heat Pump Fan Not Turning
    Start by checking the capacitor properly. It may not have any physical defects but it could still be internally compromised. Compare its rated micro-farads against the actual. You may need to simple change out the capacitor. Also ohm out the motor windings as it may tell a story.
