    Mar 2011
    uk
    32
    practical way of removing air in system
    Hi guys just wondered if any one could recommend a practical way of recovering NCG in a system with out costly destruction charges an hrs of labor.
    Auckland
    67
    3,362
    31
    Re: practical way of removing air in system
    What refrigerant are we talking about, if ***** based, recover system charge , evacuate as well as find the leak. And start again with new refrigerant charge.
    If ammonia, do a high side purge , then find the leak and repair, because the problem will only re-occur.
    Dec 2008
    Portugal
    42
    1,039
    13
    OR buy an automatic air purger. Please note that the water vapor will stay mixed with the ammonia and will not be purged. Water in the system is not good to the plant. There is also automatic machines to remove water from the system.
    Apr 2006
    35
    1,646
    do the job properly there is no skirting the proper procedure! recover the charge, do a pressure and vacuum test to locate the leak, recharge the origional gass in. check it again don, the better you are at it faster it will go!
    Now in Redvers Sask.
    Oct 2003
    56
    5,519
    28
    Big or small system? What kind of compressor? With service valves on the compressor itselves?
