Thread: Gauge readings
    Nov 2013
    38
    1
    Gauge readings
    Hi all......I have recently switched from install to service could somebody please tell me roughly what my readings should be for each refrigerant eg r410 7bar. Thank you!
    3,856
    Re: Gauge readings
    There isn't a correct pressure for a particular refrigerant, rather the pressure would correspond with the evaporating and condensing temperatures the system is running at.
    These temperatures would be dependent on the load, cleanliness of the coils and filter, air flow (or water in case of a chiller), refrigerant charge level, and ambient temperatures.
    You will in time get an idea what range of pressures you would expect a particular system to be running at based on experience. In the mean time study a pressure temperature chart and see how the two are linked.
    Auckland
    74
    3,357
    37
    Re: Gauge readings
    sounds like you have been dropped in the deep end by your boss. No short answer to your question, you should be working with a service tech.. and develop a full understanding of refrigeration systems.
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Gauge readings
    Hi, johnyaircon
    Welcome to RE forums ...
    Quote Originally Posted by johnyaircon View Post
    Someone push you into trouble water ....but don't worry ... you are a young man and eager to learn .... the best suggestion is to search RE forums and read interesting posts ... there are plenty of them ....
    for beginning you can start here ... http://www.refrigeration-engineer.co...rigeration-101
    Hope this will be of some help to you ... of course we are always here for help
    Best regards, Josip
