Thread: Heat pump H2O for -20 C
14-03-2006, 11:09 AM #1
I have been in visit of one chiller producer and he claimes that he can produce chiller for -20 C outdor temperature with R 134a,single stage compressor Bitzer.He show me one such chiller and I coud not see enithing spectacular on it only have biger air heat exchanger then one for normal ambient temperature.
Any ideas?
Renato
14-03-2006, 09:50 PM #2
Re: Heat pump H2O for -20 C
Sure, why should this be not possible and the fact that R134a is used doens't change anything.
But why then not use a drycooler when it's outside -20°C?
You don't need a chiller at all at this conditions.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
15-03-2006, 10:24 PM #3
Maybe they are claiming it works as a heat pump at -20°C ambient air temperature, which is clearly a marketing blahblah.
16-03-2006, 11:13 AM #4
Hello guys,
16-03-2006, 06:11 PM #5
Yeah, it works. Oops.... I forgot the low pressure switch bridged out.
New Heat Pump Forum
By Argus in forum Heat PumpsReplies: 17Last Post: 10-04-2010, 09:12 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
small heat pump to improve efficiency of gas furnace?
By star882 in forum DomesticReplies: 8Last Post: 24-02-2007, 05:17 PM -
Rebuild air2air heat pump
By stalker in forum Technical SpeculationsReplies: 3Last Post: 02-11-2006, 10:10 AM -
heat pump capacity adjust
By Lc_shi in forum FundamentalsReplies: 5Last Post: 14-02-2006, 07:32 AM
