Results 1 to 14 of 14
    Nov 2013
    Turkey
    58
    12
    Most efficient water temperatures for Daikin EKHBRD016ACV1 heat pump?
    Last month I had an amazingly high electricity bill after two months of using the heat pump.
    I wondered what the most efficient temperature range is for this high temp heat pump system..
    Maybe I had it set to too high.
    I'd hate to get a such bill again
    Many thanks, -turgut
    Dec 2008
    564
    Re: Most efficient water temperatures for Daikin EKHBRD016ACV1 heat pump?
    Afternoon turqut,
    From the model number I believe that you have installed a Daikin Altherma HT air source heat pump.
    What temperature do you have the domestic hot water set at? Do you find the domestic hot water, hot enough or possibly too hot?
    What temperature do you have the space or central heating water set at?
    is the house at a comfortable temperature?
    Are you using the Daikin Altherma to supply heating via radiators or under floor heating?
    Are you using the system in weather compensation mode?
    If you can come back with some figures we may be able to help you.
    Bedford. Now retired and trying to relax.
    Nov 2013
    Turkey
    58
    12
    Helo, thank you very much for your wonderful message.
    I have the domestic water set to 50 degrees. I try to keep at the lowest comfortable setting. Just enough for showers and dishes.
    I have radiators, the house is made of concrete, Apart from beams, gas cement blocks are used.
    All windows have insulated shutters. About 150 square meters of space to be heated.
    Prior to the large electricity bill, I had the system on weather compensation.
    Right now I am trying manually. I have the radiator water set for 45 degrees. I usually manually vary it from 42 to 52 degrees. The weather compensation measurements were a bit warmer; 50 to 60 degrees usually.
    Nov 2013
    Turkey
    58
    12
    PS: I try to set the house around 20-22 degrees.
    Dec 2008
    564
    Morning Turgut,
    There are ways of adjusting the range of the water temperature in conjunction with the outside ambient. The system may still be set in its default settings. If you access the commissioning menu, you should be able to make some adjustments, just be careful what you adjust and make a full note of the settings before and after any adjustments, then if you need to you can reset them.
    Jan 2014
    المملكة السعودي&
    49
    1
    اعزائي صباح الخير لدي مشكلة في جهاز تبريديوجد لدي اعطال وهي ارقام203 و11 و12 امحيها ولكن ترجع للضهور مرة تانيةافيدوني وشكرا لكم علما ان الجهازsb210
    Nov 2013
    Turkey
    58
    12
    Quote Originally Posted by hyperion View Post
    Morning Turgut,
    Many thanks - yes I'm daily in that menu. I tweak settings hoping to improve things.
    My point was, for example, is it better to set the water temperature at 40-45 degrees and have it run almost continously, or set it to 50 degrees so it stops once in a while. I just don't know the efficiency curve of the heat pump.
    Dec 2008
    564
    You may find that by changing the parameters for the water temperature range in the weather compensation for the space heating, that you reach a suitable point that will allow the unit to function automatically and achieve its optimum performance level.
    The lower the water temperature the more cost effective and efficient the system will be.
    If you PM me with some of the main parameter figures including local ambient temperature etc, I will see if I can identify any adjustments that could be made to help.
    Nov 2013
    Turkey
    58
    12
    Unfortunately the board says that I'm not allowed to PM with my account.
    I'm not sure which parameters you require, but the outside temperature is 8C right now. Goes up to 15C during the day, and falls down to 5C maybe towards morning.
    Auckland
    74
    3,357
    37
    Hi, the concrete structure will be acting as a heat sink, once stabilized the heating load requirement will reduce. Try monitoring interior wall temperatures to gauge variations.
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by tkalfaoglu View Post
    PM will be available to you after you have made 15 posts.
    Oct 2010
    Poland
    13
    How many kWh did your HT used? Understand that outside temp is around 0* at night...
    I use my HT in a 150m2 concrete house as well. ( insulated with 5-10cm styrofoam by previous owner ).
    Only high temp radiators in the house
    Domestic hot water is set to 55*C once a day and reheating to 45*C as needed when it drops to 35*C
    Heating is outside temp dependant. Currently set to 40*C at +15*C outside and 60*C at -15*C.
    January has been cold with temperatures down to -19*C.
    Our HT used 1183kWh during January, for heating and DHW.
    In your "mild" climate it should be way less.... so what was your consumption, and of curiousity, how much do you pay for 1kWh in total.
    Nov 2013
    Turkey
    58
    12
    Hi there. I heat about 150m2 of this house as well. For example, the radiators in the basement and the guest rooms are turned off. However, alas, no extra insulation. I'm glad you can get away with -15c to 60c. My HT used 2300kWh two months ago, but this month I managed to bring it to 1200kWh - mainly by tweaking the settings to your settings, and also bundling up and reducing the heating from 23-24 degrees to 20-21
    For that 2300kWh I paid 750TL, about 206 pounds UK, or US $339.
    It hurt
    I also noticed that I should not have the house resume heating full blast early in the morning -- that's when the outside is the coldest and it's hardest to extract any heat from outside.
    Oct 2010
    Poland
    13
    1200kWh... so far for February?
    Well, for us 60* at -15* works fine... and that's enough even @ -20*.
    No... you shouldn't let the house "cool" down and resume heating at full blast in the morning.
    Obviously the HT will use least kWh when not working... but try to find a setting for your house when it works longer periods ( maybe even 24/7 at coldest days).
    That means, say you set 22* desired temp ( where do you have the controller located? )
    Adjust the settings temp at High outside temp say 15*C and at -15*C or the lowest you normally have for your area. Set the temperature out no higher than HT will just keep 22*C or 21.8* ( @ 22.5*C in the house will stop the HT )
    You will have a constant heating ( more comfort ) . HT will work with less effort and just "maintain" the tempin the house, without the need to bring it up in the mornings . No peaks... just keeping it steady.
    Do you have any temp data for your location... average temp in winter? How many winter month ...
    Try out different settings, write down ( log ) the kWh consumption....
    Write down what temp outside, what temp HT delivers to the radiators... and kWh used... say average for 4 or 6h...
    Good luck
