Results 1 to 2 of 2
    Nov 2007
    IRELAND
    11
    Climaveneta CVM3000 problem
    I've a problem with a CVM3000C that has four systems but each of the four systems has a fault that will not reset.
    Three of the faults are for a comp overtemp the other is for a HP
    None of these are real alarms and the input for each of these is not putting a fault signal into the board.
    Has anyone come across this or has any suggestions
    hector6's Avatar
    hector6 Guest
    Re: Climaveneta CVM3000 problem
    If you have the 240 volt control circuit made but the fault won't clear it's usually a fault on the main PCB ( cvm )
    You are best to speak to Climaveneta uk and they will give you a price for a new one.
    Good luck.
