Results 1 to 10 of 10
Thread: Loctite 567
    Oct 2013
    Australia
    45
    Lightbulb Loctite 567
    Can you guys see any problems using a modecum of this stuff on flares?
    It says it's halogenated hydrocarbon safe, along with other stuff, so just interested more than anything
    3,856
    Re: Loctite 567
    I'd be concerned some of it could get into the compressor or expansion device or such and cause trouble.
    I just use some compressor oil i keep in a small squeezy oiler for the flare face, i put a little oil on the threads too. sometimes a little grease behind the flare to lube the nut so it don't want to twist the pipe.
    Have a look to see if Nylog is available locally to you, it will be more what you are looking for as its a cross between a lube and a sealant and based on compressor oil.
    Aug 2001
    Gold Coast, Australia
    600
    28
    Re: Loctite 567
    Nylog, as IM says. Heatcraft usually sell it.
    Oct 2008
    mallorca, spain,
    75
    768
    Re: Loctite 567
    hi, sorry but why make a simple job ( making a flair) more difficult ?= sedgy
    Auckland
    74
    3,357
    37
    Re: Loctite 567
    Loctite 577, but a good flare is even better.
    Aug 2007
    Adelaide Australia
    70
    562
    Re: Loctite 567
    Hi Sparkletron
    I agree with Magoo and sedgy nothing better then a well made flare therefore no sealer required. You need to be careful what Loctite you use as some will be dissolved by oil and if you are relying on it for a seal it will eventually leak.
    Paul
    Born to fish, forced to work
    Oct 2013
    Australia
    45
    Re: Loctite 567
    I ended up getting a flare to hold 3000KPA for over 24 hours with no leak, even though the brass service valve it was seating on had some damage.
    I have a bees knees flare tool and I usually just use a tiny bit of oil on the flare and have no dramas. This one just concerned me as it was a second had unit that was being reinstalled.
    I trie to get loctite 554, and nylog but at that time I coulnd't source it.
    Thanks for all the replies, there is a lo
    Split Croatia
    57
    6,151
    36
    Re: Loctite 567
    Nylog is perfect solution for small scratches at flared surface. If scratch is deep, then there is no solution other than re-flaring.
    3,856
    Re: Loctite 567
    If the scratch is in the brass, you can polish it out with maroon scotchbrite used in a circular motion so any additional scratches don't make a leak path from inside to outside.
    Sep 2006
    8
    Re: Loctite 567
    You should be able to get Nylog from SRW and other smaller wholesalers.
