Results 1 to 11 of 11
Thread: P29 Sanyo fault
    Mar 2011
    Dublin
    36
    55
    14
    P29 Sanyo fault
    Hey all, was at a p29 sanyo fault earlier. I didn't get much time to look a the outdoor as light was fading, I'm going back tomorrow.
    My compressor windings were all the same resistance: 0.7 ohms
    My HIC board had a reading of 298 between P and N on each phase of the inverter.
    Anything else I can check?
    It's a split: Spw-cr484gvh56
    Oct 2007
    manchester
    5,639
    45
    Re: P29 Sanyo fault
    you need to power down the hic board- unplug the u,v,w and + and - test resistance accross + to u,v,w then - to u,v,w then reverseleads toget more readings, all 3 sets of resistances should be the same, either continuity or infinity- ideally a analogue meter
    megger the pot to earth too
    Mar 2006
    Lancashire
    1,859
    28
    Re: P29 Sanyo fault
    Is that Hic board error fault?
    If it is my advice would be to condemn it or set it on fire!!
    Marc
    Oct 2012
    Russia
    42
    392
    Re: P29 Sanyo fault
    P29 its error of board or compressor. Compressor try to start? Im from pad, dont have manual on him.
    Mar 2011
    Dublin
    36
    55
    14
    Re: P29 Sanyo fault
    Quote Originally Posted by install monkey View Post
    I'll give that a try thanks. Meant to add that I tested it yesterday and it's not down to earth,
    Mar 2011
    Dublin
    36
    55
    14
    Re: P29 Sanyo fault
    Quote Originally Posted by RusBuka View Post
    No, when I was at it the compressor didn't even try to start, that's why I think it's the compressor, I think it's locked.
    Oct 2012
    Russia
    42
    392
    Re: P29 Sanyo fault
    Mar 2011
    Dublin
    36
    55
    14
    Re: P29 Sanyo fault
    Thanks.
    The readings from the HIC board looked good so I called the compressor. I'll update if I hear any more about the system.
    maxime's Avatar
    maxime Guest
    Re: P29 Sanyo fault
    The fault P29 can come from the CT around the line of the power supply.
    Max
    Oct 2007
    manchester
    5,639
    45
    Re: P29 Sanyo fault
    put an inverter checker on it to proove your hic board is ok
    Nov 2008
    scunny!
    35
    302
    22
    Re: P29 Sanyo fault
    Change them both make more money ;-)
Tags for this Thread
