Results 1 to 1 of 1
Thread: Pipe fittings and Valve DWG's
22-01-2014, 02:19 PM #1
Hello,
I work for a refrigeration piping company supporting the project managers.
What I'm looking for is someone to point me in the right direction I'm compiling a database of all the pipe fittings and valves we use for this database I'm trying to get all the AutoCAD DWG files for the retailers pipe fittings and valves, in theory if I need to do a drawing for a job all I have to do is copy and paste the necessary valve or fitting into the drawing then draw in the piping coming off of these. We use valves and fittings from BSS group, Ashworth, Danfoss etc... Is there somewhere I can get theses DWG files, If not a DWG a PDF with all the measurements would suffice as I could re-draw it in AutoCAD. I've looked through the above companies catalogues and while they contain sketches of the valves and fittings they aren't measured nor able to drag and drop into AutoCAD...
What I'm asking for in short is a link to find these DWG files or a place where they can be bought from the retailer.
Any advice will be greatly appreciated.
Regards,
Johnny13
