    3,356
    Viking oil pump selection programme
    Jul 2007
    Czech
    61
    373
    Re: Viking oil pump selection programme
    Good job Ranger, thanks.
    Jan 2006
    Croatia
    68
    2,261
    31
    Thanks for share ...
    Best regards, Josip
    Oct 2007
    New Zealand
    52
    Viking pumps suck. Fiddly bloody things with the way you set up the clearances as well as shaft seals between bearings. Id rather have a Mycom or even the antique David Brown pump.
    3,356
    Quote Originally Posted by kiwi View Post
    Great, you can now easily match up Viking capacity with a Mycom pump replacement!
    You could also buy a few Viking shaft seals as they are pretty cheap compared to Mycom
    $200 compared to more than $1000.
    Oct 2007
    New Zealand
    52
    Indeed. Thanks for the link!
    The Viking does have some redemption in the lower priced seal, and not to mention keeping me working!
    3,356
    For me the hardest thing is replacing carbon bush in idler gear. Get it wrong & you crack it radially.
    Paul Z has mentioned in the past about carbon faces wearing out. As he states replacing with antimony carbons is the only way to go.
    We have also seen many cases of by lock nut coming loose. Best to locktite or make up double nut which also is locktite secured.
