Results 1 to 27 of 27
Thread: Nh3 systems
    Mar 2006
    calif
    Nh3 systems
    I am looking for information on Nh3 systems . I work at a soft drink company and would like to understand the refrigeration system on our fillers. We have 10 Vilter compressors that range from 25 hp to 125 hp that feed three chillers in the filler room. next to each chiller appears to be a liquid reciever just before the metering device
    thats about the extent of my knowlege and I cant find anything in my refrigeration books from school
    thanks
    Jun 2001
    N.Ireland
    1,630
    Re: Nh3 systems
    Hi CT2
    Would these be "MO JO Plants
    Mojourney plants, built in the good old USA for syrup cooling.
    If they are I will explain their operation.
    Kind Regards. Andy
    Mar 2006
    calif
    Re: Nh3 systems
    Andy , thanks for the reply
    yes , the system cools the mix , it is then pumped into the filler where the mix and co2 are filled into the container
    Jun 2001
    N.Ireland
    1,630
    Re: Nh3 systems
    Hi CT2
    A simple flooded NH3 system.
    liquid is feed from the receiver out side. This HP liquid is injected into the Surge vessel inside thru an injector nozzel, this causes circulation of the ammonia in the Surup cooling jacket the liquid entering goes to the top of the jacket, sucking cold Ammonia from the bottom of the Jacket and mixing it to the incomming ammonia by venturi effect. The charge is resonably critical in these systems, as is the condensing temperture and the opening degrees of the injector valve, all effect the proper circulation in the jacket.
    Hope this helps
    Kind Regards. Andy
    Mar 2006
    calif
    Re: Nh3 systems
    so if I understand you correctly the ammonia doesnt actually vaporize ,it remains in a liquid or saturated vapor in the chiller
    does the ammonia vaporize in the system or do the compressors pump liquid?/ saturated vapor?
    Mar 2006
    calif
    Re: Nh3 systems
    how do you determine if the charge is correct. I understand that occasionally ammonia has to be added to the system. On each of the Surge vessels there is a sight glass and I have watched the level changing during operation
    Mar 2006
    calif
    Re: Nh3 systems
    please excuse my little knowlege on these systems , I would like to learn as much as I can about them
    Mar 2006
    Philippines
    124
    Re: Nh3 systems
    Hi CT2,
    I used to work in coca-cola, and now I am a contractor of their refrigeration. Most of the system is carbo cooler MO JO. What company are you working? eric
    Aug 2005
    5,302
    Re: Nh3 systems
    Hi CT2,
    so if I understand you correctly the ammonia doesn't actually vaporize ,it remains in a liquid or saturated vapor in the chiller
    The liquid does evaporate into a vapor inside of the coolers. The compressors only compress vapor, NEVER liquid.
    I do not have any literature for the systems you have, but you may be able to find some information by doing a an internet search.
    If I can find some information for you, I will post it here.
    Please ask any questions you may have. We are glad to help.
    Jun 2001
    N.Ireland
    1,630
    Re: Nh3 systems
    Quote Originally Posted by CT2
    CT2 please see Icemans Post.
    Kind Regards. Andy
    Jun 2001
    N.Ireland
    1,630
    Re: Nh3 systems
    Experience, is essential
    Suction superheat is also required
    Level is important
    Also the product leaving temperature, the operator will have a good idea if the plant is cooling to it,s usualy standard.
    Kind Regards Andy
    Mar 2006
    calif
    Re: Nh3 systems
    Andy , Guappo and us iceman
    thank you all for your help
    Guappo , I am working at the 7-up bottleing co of San Franscico
    Us Iceman: I have tried several google searches on nh3 refrigeration and havent found anything that teaches plant systems . I work on night shift and unfortunatly the journeymen working day shift know the most about our system and are willing to share the least with the rest of us
    we had a case the other night in which our product temps rose to 60 degrees F and thankfully with my limited knowlege of our system I was able to find the trouble and make the correction
    Aug 2005
    5,302
    Re: Nh3 systems
    CT2, try searching on the RETA website.
    http://www.reta.com
    They will not have instructional material listed you can read, but you can order the industrial refrigeration books. Most of the information you need is within the first two volumes.
    Yes it will cost you some money, but you WILL get some very good information on the basic systems.
    ...the journeymen working day shift know the most about our system and are willing to share the least with the rest of us
    Job protection or just selfish. Unfortunately, this is encountered by most people starting out. Industrial refrigeration is the worse because the people that know something sometimes don't like to share.
    I found this to be true when I started. I also used the RETA books at that time because they were the ONLY source of information available. Other than contractors or manufacturers who will help, but usually only when you are spending money!
    Mar 2006
    calif
    Re: Nh3 systems
    US iceman : thank you I will look at the sites you have mentioned . I dont mind spending money on books that will make money for me in the long run
    Dec 2005
    7
    Re: Nh3 systems
    You can go to reta. com and get a order form and order refrigeration books. Its cheaper if you become a member. You can order the books and the exam and answer sheet and mail the answer sheet in to reta and they will give you a certificate. My company paid for my as part of training. I have recently completed Ref. course 1-2-3-4. Bacic electricty 1-2 and Control theory 1-2. hope this helps and good luck.
    Aug 2005
    5,302
    Re: Nh3 systems
    Ken,
    Have you taken the CARO or CIRO certification exams?
    What did you think of the training material and books?
    Thanks,
    US Iceman
    Dec 2005
    7
    Re: Nh3 systems
    Hellow US Iceman. No I have not taken the CARO or CIRO exams yet my employer told me if I wanted to take them they would pay for it so I will probably check in to in later. I found the books to be very useful Ref. 1-2-3-4- and basic Electyicty 1 and 2 However I found Control Theory 1-2 to be boring and a little to advanced for me at this time. I highly recommend Ref. books 1-2-3 and 4 for anyone starting out in NH3. Ref.
    Aug 2005
    5,302
    Re: Nh3 systems
    Book 3 is currently undergoing revision at this time.
    I also seem to remember hearing something about another book being revised, but I don't remember which one it is.
    If your employer will pay for the certification exams you are a lucky one. Some employers are beginning to take this seriously, others are waiting for it to be free I think.
    Mar 2006
    China
    83
    Re: Nh3 systems
    Hi,CT2.I am a new too.but I have read a book,maybe help you.The name is "Industrial Refrigeration HandBook".Mc Graw Hill published.
    Mar 2006
    calif
    Re: Nh3 systems
    Guapo , Iceman and Andy
    well I got a bit of an education on our system and I walked away with a better understanding of how things work and what does what.
    we have three frame and plate chillers and one of them leaked product.
    only one of the mechanics there had any idea how this was assembled and that was years ago. he only remembered the factory rep putting it together.
    we took it apart and changed the gaskets on all of the plates and put it together 4 times , still chasing the leak when someone remembered that we had three plates in stock from the installation.
    after replacing the end plate and two additional plates we stopped the leak.
    I evacuated the system on my shift, I should say the isolated part of the system, found a small ammonia leak with a smoke stick , fixed that leak , evacuated again and after holding 30 " of vacuum we put it back in operation
    I do thank you all for your help, anthony
    Aug 2005
    5,302
    Re: Nh3 systems
    When you say a "smoke stick" I am assuming you are using sulphur sticks??
    Don't they smell nice.
    Mar 2006
    calif
    Re: Nh3 systems
    yes, sulphur sticks
    yea , when you hit a leak I dont know what is worse , the ammonia or the smoke from the sticks
  23. #23
    Croatia
    68
    2,261
    Re: Nh3 systems
    yes, sulphur sticks
    Hello, CT2,
    but definitely it is 100% proved that you have a leak then you have a break (for beer) waiting for fresh air
    Best regards,
    Josip
  24. #24
    Aug 2005
    5,302
    Re: Nh3 systems
    ...when you hit a leak I don't know what is worse , the ammonia or the smoke from the sticks
    My vote is for the sulphur sticks. Ammonia smells pretty good compared to the sulphur cloud.
  25. #25
    Oct 2004
    INDIA
    Re: Nh3 systems
    All the compressors compress low temperature low pressure vapour not liquid.If the liquid enters into the compressor chamber it is called liquid stroke which is very fatal for the machine.
    AMARNATH JHA
  26. #26
    Croatia
    68
    2,261
    Re: Nh3 systems
    Quote Originally Posted by AMARNATH JHA
    AMARNATH JHA
    Hello, AMARNATH JHA
    yes, definitely must be vapour, but not necessarily low temp and low press
    to pump liquids we use pumps not compressors,
    it is dangerous causing damages but not fatal for all compressors
    Best regards,
    Josip
  27. #27
    Mar 2006
    calif
    Re: Nh3 systems
    I am mostly familiar with refrigeration compressors and I
    I wasnt there to see them draw the liquid out of the chillers reciever , but I was there when we slowly throttled liquid back in the tank, and that gave me a better understanding of what was taking place in the system
  1. contaminants in ammonia systems
    By Johnny Rod in forum Refrigerants
    Last Post: 17-10-2011, 05:26 PM
  2. My local Apprentice Training Classes
    By shogun7 in forum Training
    Last Post: 17-03-2007, 03:10 PM
  3. Refrigeration alarm systems
    By tonydeith in forum Supermarket Refrigeration
    Last Post: 27-04-2006, 01:43 AM
  4. HFCs for flooded systems?
    By garyb in forum Refrigerants
    Last Post: 21-04-2006, 10:02 PM
  5. Diy Systems
    By kewlman in forum Air Conditioning
    Last Post: 22-07-2005, 01:08 AM
