Thread: Compair fridge air dryer
16-01-2014, 07:37 PM #1
Hi guys
after some help with Compair dryer, not familiar with these dryers anyway when testing it runs for about I minute and then stops and doesn't kick back on , when on comp and fan running.its only small unit 240v and r134a 0.5kg not much on it just drain ,comp, fan. I put 240v direct to comp and fan and they run but comp did start to ice up after 5mins. Small digital controller that just says dry,
thanks
16-01-2014, 08:25 PM #2
Re: Compair fridge air dryer
test the controller for output to the comp, could be a stuck relay or parameters wrong
21-01-2014, 06:58 PM #3
install monkey
