Results 1 to 13 of 13
    Mar 2011
    Dublin
    36
    55
    14
    Tool for pipe sizing??
    Hi guys, just wondering if anyone knows of any tools for correct pipe sizing? I'm still always getting confused.
    An engineer that I used to know had what can only be described as a flat piece of copper with the different sizes cut out. You'd then place your pipe in the cut outs to determine the correct size. It wasn't home made, can't remember the make though.
    I've tried wholesalers here but nobody has a clue what I'm on about.
    Anyone know of any tools I could buy?
    Oct 2007
    manchester
    5,639
    45
    Re: Tool for pipe sizing??
    1 of each sized flare nut??
    3,856
    Sometimes if i'm not sure ill put an adjustable spanner round the pipe and either read off the scale on it if it has one or use a tape measure to measure the gap in the jaws.
    May 2012
    59
    1,528
    36
    Quote Originally Posted by eire1 View Post
    There was a copper one a few years back but I think it was a freebee from
    a pipe manufacturer. Although there are a lot of them kicking around you
    will struggle to find new ones now.
    There was a plastic one, that was sold but I don't think they are in stock now.
    If you want you could make one.
    Use a large diameter pipe and cut a piece about 4 or 5 inches long
    slit it open and flatten it out. Draw a half circle from a selection of
    pipes. You could do 1/4, 3/8, 1/2, 3/4 and 7/8 and then cut and file
    to shape. I got the lads to do them in college and it looked good and
    did not take long. If you measure it well and place the half cut pipe holes
    in the best location down both sides then you can make it about 3" by 2".
    Another method commonly used is to cut a selection of pipes about half
    an inch long and thread them through a large key ring or even make a ring
    out of brazing rod.
    Rob
    Feb 2009
    telford
    2,092
    33
    the adjustable and steel ruler the best idea,works for me,slide rule?
    Jan 2011
    57
    15
    Flaring tool vice? Just put it around the pipe and that will tell you the size??
    Jan 2011
    57
    15
    Flairing* any the hole in the vice will tell you what size it is
    Oct 2007
    manchester
    5,639
    45
    you pick it up over time, pipe sizing- until then its usually stamped on fittings and down the seam of the pipe with the manufacturer too
    May 2010
    Russia
    168
    15
    I use adjustable wrench.
    Mar 2011
    Dublin
    36
    55
    14
    out of brazing rod.
    Rob
    I might try that, make's perfect sense.
    Thanks for all your suggestions, keep em coming.
    Mar 2008
    Manchester
    74
    33
    Hi Mitsubishi Electric uk gave my engineer one for free. it was card not copper but did the trick. try them they are based in manchester Uk. Unfortunately we use imperial sizes so in standard copper installations they go:
    1/4 3/8 1/2 5/8 3/4 7/8 1/18 1/38 1/58 and so on. You can also but a cheap vernier gauge
    In steel it is different
    Lastguest
    Oct 2007
    manchester
    5,639
    45
    have you read the other posts- what the f**k has weighing scales got to do with this??
    Oct 2008
    newbury
    1,444
    37
    Quote Originally Posted by install monkey View Post
    cut a metre off each size and weigh it. then when you are unsure of what size it is cut a metre and weigh that. Compare against your size V weight chart and bingo
    This will only work if you cut exactly a metre as too much or too little will affect the weight. Also you must make sure you are working in the same gravitational pull as when you first weighed. If for example you weighed it on earth and you tried this method whilst working on the Hubble telescope in deep space for example you could get very confuzzed. Other than that it's 100% fool proof.
    As an aside my ex's father was heavily involved in the Hubble program and talked me through the Hubble telescope refrigeration system which was needed to keep the lens from distorting.
Tags for this Thread
