Results 1 to 9 of 9
    3,856
    Van storage for cans?
    Been tidying out the van and realise ive got around 20 spray cans, grease, oil, paint, leak spray, cleaners, etc
    Has anyone got any bright ideas for storing them?
    Dec 2008
    564
    Re: Van storage for cans?
    Maybe a plastic storage container!
    Bedford. Now retired and trying to relax.
    11,025
    Start collecting wine bottle carriers from the supermarkets.
    3,856
    I was thinking wine bottles! Think the real problem is i haven't got space for them, or i got too much stuff!
    Oct 2007
    manchester
    5,639
    45
    3,856
    Quote Originally Posted by install monkey View Post
    Hahaha! NO!
    Feb 2009
    telford
    2,090
    33
    milk crates,turn em upside down a step up,or macdonalds do them cardboard things at the drive thru
    Jun 2011
    Australia
    44
    336
    21
    Just tie them to a length of string & tow them behind the van - bit like when people got married in the black & white times!
    Aug 2001
    Gold Coast, Australia
    600
    28
    A section of PVC drain or conduit - whichever is a better fit. Cut it as long as you like - I did 2-3 cans high. Cut a slot down one side ( leave the ends to retain the tube structure) to lift cans. Or use some wire or thin sheet metal to make a 'puller'. That may be better as the nearest size tube I could find was about 15-20mm wider than the cans, so a sheet metal puller may help take up space & reduce rattle?
    In my case I dropped them behind the metal tool box where I had some dead space. If you can keep the same type of can in each tube, most used on top if they're different contents, it works reasonably well.
