Results 1 to 8 of 8
    Feb 2010
    Bulgaria
    36
    Sanyo ecoi - problem
    Hello All !
    I bought a used Sanyo Ecoi VRF systems with one outdoor unit and 12 indoor units fitted with 12 wired controllers.
    Before to install everything i powered the indoor units to check them electrical .
    5 of the indoor units did not power and red led is blinking inside on the board .
    The models of the indoor units are SPW-KR94GXH56B (8 units ) and SPW-KR124GXH56B (4 units)
    All SPW-KR124GXH56B did not work + one SPW-KR94 . All with same problem with blinking red led.
    The outdoor unit models is SPW-C1155DXH8 .
    Anyone can suggest what can be the problem ?
    Thanks in advance
    11,025
    Re: Sanyo ecoi - problem
    Did you connect all of the indoor unit to the main unit when you tested them?
    Oct 2007
    manchester
    5,639
    45
    auto address em-
    red light on indoor pcb is normal
    power outdoor , link cno4 for auto address
    wire all controllers in, check setting modes 12,13,14 on remotes
    then ring tony duffy-tech guy on RE
    Oct 2007
    manchester
    5,639
    45
    click on link below for service manual
    http://www.mediafire.com/view/yzyby3...%20service.pdf
    Feb 2010
    Bulgaria
    36
    No i just run one by one each with wired control to check if they work . Even i did not connect to the outdoor .
    Oct 2007
    manchester
    5,639
    45
    did you get the manual from my previous link
    Feb 2010
    Bulgaria
    36
    Yes, i did . Looks so complicated as i never run VRF .
    So you said red blinking is normal ?
    Oct 2007
    manchester
    5,639
    45
    yep its it shows indoor pcb is powered and transmitting a signal- transformer hasnt 2 outputs 12 and 24v - best option is get them fitted quick to then test it properly
    usually sanyo kit is ok, compressors are expensive- but you can disable a faulty pot
