Thread: The capacity doesn't change
01-01-2014, 10:48 AM #1
I have a problem in sabroe compressor in capacity, the capacity doesn't change, it's zero
How i can solve it?
Please help me and thank.
01-01-2014, 11:38 AM #2
Re: The capacity doesn't change
OK, Sabroe reciprocating or screw, you know more?, model, CMO, SMC, SAB, SAB-Frick ......
And Happy New year, Josef.
01-01-2014, 12:09 PM #3
Sorry ,it type is screw and it model is(Xjf120l0962ff)
And alot of happy for you and other guys.
01-01-2014, 12:29 PM #4
Thanks for the information, have you checked the coil?, What oil pressure, discharge pressure, the number of operating hours, the oil changed? When it all well, will be a problem in the pressure relief valve to regulate, you know what I'm writing?
01-01-2014, 12:39 PM #5
Yes,sair i will make cheack and come back.
01-01-2014, 01:10 PM #6
Every thing you tolled me is good,
But maybe the problem at coil, what is your ordered?
01-01-2014, 01:13 PM #7
Please your email.
01-01-2014, 08:20 PM #8
If load solenoid coil is damaged, swap unload coil to load coil to see if it works.
You can also manually push directional control valve center with a small punch or screwdriver.
Try both ends as it may be jammed.
03-01-2014, 08:22 AM #9
What is the controller? Unisab? Quantum?. Does it really not load/unload or is it not reading at the panel? Could be a faulty pot/transmitter.
Current draw will give it away if it is loading or not.
