    Oct 2005
    Malta
    8
    Sanyo inverter split unit
    Recently I am looking for a sanyo a/c with inverter charged with r410 to install at home. As i never looked at this brand before i was hoping if anyone has worked on a sanyo a/c or knows the pros & cons.
    Thanks in anticipation
    Oct 2005
    preston lancashire
    12
    Re: Sanyo inverter split unit
    my company uses sanyo all the time more or less trouble free
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    I install Sanyo also, and find them to be very good units. The larger units are almost identical to Toshiba
    Karl
    May 2006
    Sussex
    362
    Note, the 3.5kw Sanyo inverter has the room temp sensor on the remote controller. Probably okay for a domestic arrangement, but don't put the controller in a drawer.
    I have had engineers install about 6 of them and all okay, no probs.
    But, check out Daikin's summer specials: 2.5kw @ £230, and 3.5kw @ £281. I think Sanyo 3.5 is about £380-ish.
  1. Sanyo CR 903GY Multi Unit
    By bobjob in forum Air Conditioning
    Last Post: 29-07-2006, 04:27 PM
  2. Split unit (Recommendations)
    By Smokey in forum Air Conditioning
    Last Post: 26-07-2006, 10:04 PM
  3. Replies: 8
    Last Post: 20-05-2006, 04:21 PM
  4. Replies: 5
    Last Post: 22-06-2005, 07:41 PM
