Results 1 to 10 of 10
    Apr 2012
    Iraq
    35
    623
    Discharge line bypass device utility ?
    I checked a floor standing 4 ton LG split air conditioner unit
    there was a bypass valve connecting between the compressor discharge line
    and suction line
    the tube connect the valve from discharge line is larger than the capillary which connect the bypass valve to the compressor suction line
    these word are on the valve name plate
    SP 280 psi
    what its utility
    Apr 2008
    Canada
    253
    4
    21
    Re: Discharge line bypass device utility ?
    Sounds like it is used for capacity control. It's either regulating or opening at 280psi.
    See Link: http://www.heatcraftrpd.com/res/pdfs...ty_Control.pdf (Page 8-9, Fig 2a)
    Another reason for piping a line to the suction would be for over pressure protection. Its not recommended here in Canada but still seen frequently.
    Apr 2012
    Iraq
    35
    623
    I took a photo for the valve from another unit
    bcoz the tag on the valve of the first unit was removed
    May 2010
    Russia
    168
    15
    it's heat pump unit or not?
    Apr 2012
    Iraq
    35
    623
    its heat pump unit
    48000 btu
    May 2010
    Russia
    168
    15
    I had seen a similar circuit design in MHI units.
    Tomorrow I can upload mhi documents.
    Apr 2012
    Iraq
    35
    623
    Quote Originally Posted by bigor_2 View Post
    im waiting
    Oct 2012
    Russia
    42
    392
    I think its like pre-error of HP. If compressor don't stop by currency/overheating with discharge->suction bypass, so let him work)))
    May 2010
    Russia
    168
    15
    kefah
    I'm sorry for my long silence.
    MHI's documents do not provide description of the work this valve.
    In some circuits he is called DPR
    In other circuits he is called High Pressure regulator valve
    Look at it
    In both cases it is safety valve
    Oct 2012
    Russia
    42
    392
    First foto - Liquid injection and HP bypass ( after condenser to the suction)
    Second foto - HP drop, bypass capillary tubes.
    See that valve in old ME blocks r22
