Results 1 to 13 of 13
    Jan 2013
    uk
    34
    8
    Mcquay Chiller problem
    hi all, we arrived on site to find a mcquay air cooled wated chiller with the alarm transition or state alarm on both compressors, I don't have the model numbers to hand just wonderd if any 1 could shed any light on the problem ??? contacted Daikin but they don't support the model...
    Cheers Matt
    495
    21
    Re: Mcquay Chiller problem
    Hi matt which mcquay chillers are they screw als with soft starter
    Jan 2013
    uk
    34
    8
    Quote Originally Posted by GHAZ View Post
    hi, theres 2 large screws, on 134a 20kgs in each, 2 circuits, i dont thinknit has soft start on, im going back in the morning so ill check then
    Oct 2012
    Russia
    42
    392
    One-screw McQuay, oil everywhere?
    Jan 2013
    uk
    34
    8
    no 2 screws, have same fault, i forgot to say that both compressors are extremely hot aswell but it comes up with the transition or state alarm for both comps
    Jan 2013
    uk
    34
    8
    solid state sorry
    Aug 2001
    Gold Coast, Australia
    600
    28
    I'm not familiar with the brand, but since you say both comp's are extremely hot, & given the alarm message, I'm guessing that they are failing to transition from Star to Delta.
    I'd be checking power, megger-ing the motors, checking the power train & if no obvious faults, try a dry start - ie. remove the compressor fuses & put it through the start sequence to see what happens.
    Oct 2012
    Russia
    42
    392
    May be its only electric heater.
    I dont understand, you try to start chiller, whats happens? Or its in stand-by mode
    Jan 2013
    uk
    34
    8
    it wont start, goes to start up and alarms out, how ever it did it to 1 circuit not 2 yesterday
    Aug 2001
    600
    28
    Did you try what I suggested?
    With the equipment I'm familiar with, having removed the Comp. power fuses you can do a dry start - a simulated start, if you prefer. The star/delta contactors & transition resistor bank will still cycle as per design (or as they left the factory) as they aren't dependant on the compressor power.
    It was a normal step in the commissioning process, to be sure that the timers were correctly set & all the switching worked as required without endangering the compressor motor.
    If something doesn't operate correctly in the dry run, you will have a loose cable, stuffed timer, stuffed item of switchgear, or stuffed transition resistors most likely. After that you're probably into the controller itself.
    Dec 2013
    United Arab Emirates
    1
    Very well explained...
    Oct 2007
    manchester
    5,639
    45
    we got a model number yet,maybe a fault code?
    Jan 2014
    India
    37
    3
    hi i have mcquay chiller MNG105.2 HA ST model im facing problem for both Circuit A & B, Circuit A showing Alarm AL:E01 Exp A not recognized & Circuit B is Low Ambient tepm start up failure & with AL:206 Low Pressure Alarm #2 what the reason and how to remove this alarm
Tags for this Thread
