Results 1 to 15 of 15
Thread: Electrical test leads
07-12-2013, 03:08 PM #1
Gents,
I'm looking for some small tip electrical test probes, to be able to test hard to access terminals.
I have a fluke 116 multimeter and the tips of the test leads are quite small but after trying to take the resistance readings on a CN plug for a Daikin condenser fan motor today I found they aren't small enough.
I ended up using a paperclip to push into the CN plug to take the readings but was hoping to be able to get a set of smaller tip test probes to use with my multimeter.
The only ones I've seen are the FLUKE TL910 but they are pretty pricey at £60
Which ones do you use?
Marc
07-12-2013, 04:47 PM #2
Re: Electrical test leads
get 15amp fuse wire- wrap it around your prongs- and secure with insulation tape
07-12-2013, 05:53 PM #3
Got a set like this,
http://www.amazon.co.uk/Fluke-Tlk287...uke+test+leads
Cost more than the tester!Mostly found in Oxfordshire, UK :)
07-12-2013, 06:36 PM #4
Go to your local MAPLIN and have a look they got plenty to choose from.
07-12-2013, 08:57 PM #5
07-12-2013, 09:01 PM #6
Marc
07-12-2013, 09:03 PM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
07-12-2013, 09:06 PM #8
07-12-2013, 09:16 PM #9
07-12-2013, 09:40 PM #10
07-12-2013, 09:59 PM #11
07-12-2013, 10:39 PM #12
Have a look on ebay,
http://www.ebay.co.uk/itm/1-Pair-20A...item43c1fcdf2b
not sure if these any good but expect there would be something there.Mostly found in Oxfordshire, UK :)
08-12-2013, 12:12 AM #13
Forget all the fancy connectors. Strip connector (choc box), one end on the probe and either a pin or paper clip in the other. Not had it fail me yet and I can abuse and lose them and not lose any sleep.
If the boss is paying, well different story
Cheers, Andy.Last edited by Tayters; 08-12-2013 at 12:23 AM. Reason: Spelling. Again.
08-12-2013, 08:17 AM #14
08-12-2013, 08:19 AM #15
Another good idea that Andy.
If the ones I've ordered ever break I'll remember that.
ThanksThe difference between genius and stupidity is that genius has its limits.
Marc
