    Dec 2005
    222
    Getting colder Temperatures on the Right side of a display case.
    Seasons Greetings Everyone! ♫♪ ♫ ♪ La la la la la - la la - la - la ♫ ♫
    OK her we go. I am developing a double-pallet sized open front display case. It is 9.5 ft.- long X 6.4 ft. High X 4.3ft. deep. It has 9ft pallet rack with 2- pallets on the bottom 2- on top rack. Its full of Test packs and its running good but the right side is noticibly colder. Example: left bottom front 40°f , right bottom front - 34°f. and 3rd shelf left front - 39°f , 3rd shelf right front - 29°f . The other locations are of a similar discrepancy. My cold air discharge air curtain is ; left - 23.3, center - 24.1, right - 23.4.
    I have built this case from the ground up. I am satified that nothing impeades my airflow but i know strange things happen when getting it to behave..
    Thoughts?
    May 2012
    59
    1,528
    36
    Re: Getting colder Temperatures on the Right side of a display case.
    Photos...............
    Could you post a few photos so we can see what it looks like?
    Rob
    Dec 2005
    222
    Pictures aren't the best it barely fits in our Lab. IMAG1244.jpgIMAG1245.jpgIMAG1246.jpg
    May 2012
    59
    1,528
    36
    What I would do is put 2 sheets of plywood over the front,
    totally covering the opening and then run. See if there is a
    difference to it running without the wood?
    That will give you an idea if it is external or internal air disruption?
    Rob
    ireland
    1,450
    41
    as with Rob, are you losing a lot of air out the bottom/front? Similar style to roll in milk chillers, but they have a hydralic front to retain air.
    pauram's Avatar
    pauram Guest
    I assume you are using propeller type fans. Assume also CW rotation, most common. They twist air to the right. Reduce static pressure on fans (could be the finned coil) and air-flow will straighten somewhat.
    pauram's Avatar
    pauram Guest
    Assume you are using propeller type fans. Also assuming evaporator coil is close to fans, rather than away from each other. Assumption also fan blades are CW rotation. Propeller fans twist air.
    To reduce this effect unload static pressure on fan blades, such as move coil away, or increase duct area(s)
