    Jul 2013
    58
    11
    Why isn't alcohol used as a refrigerant?
    Is there a reason why alcohol (or a mixture of alcohol and water) isn't used as a refrigerant?
    3,853
    Re: Why isn't alcohol used as a refrigerant?
    We'd drink it all before we got to site....
    Apr 2008
    Southampton, England
    49
    1,023
    Hi Bud,
    Some systems use alcohol. You can tell as they make a wine. Some Brandys are worse than others but in the Absinthe of any data I can't say which ones are worse. Perhaps an industry inCider could help?
    Cheers!
    manchester
    5,639
    http://en.wikipedia.org/wiki/Alcohol
    http://en.wikipedia.org/wiki/Ethylene_glycol
    courtesy of wikipedia- glycol is similarly based to alcahol
    38
    In ww2 alcohol was used as an anti freeze mix with water in high altitude aircraft piston engines, not the drinkable version though. Much to the demise of a lot of aircraft mechanics that distilled it and drank it. Dead.
    Probably before the oil based propylene and ethylene variants current these days.
    hookster's Avatar
    Apr 2007
    Hampshire
    438
    32
    http://www.grimsby.ac.uk/documents/d...frigetechs.pdf
    This should be closer to what you seek NiHaoMike
