    Nov 2013
    Colorado
    9
    my first refer service call
    one of the units I found that the capacitor is bad but I can't identify the capacitor because it's all worn off. How would I go about identifying which capacitor I should use. It looks like I have a model number on the compressor.
    3,853
    Re: my first refer service call
    Try and get a match off the compressor model number or even the model number form the unit, manufacturers or wholesalers technical department should be able to help.
    Nov 2013
    Colorado
    9
    done. unit up and running. Thanks
    Feb 2009
    54
    143
    Quote Originally Posted by 29mv29 View Post
    Replace relay also, that's the reason for capacitor failure
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Royal241 View Post
    Could you explain that?
