    May 2011
    India
    32
    92
    8
    Duct losses determination
    I have the duct sized with equal friction method, and now I need to determine the losses.
    I'm not sure about the calculation, how ever when I reffered the Carrier handbook, it says to determine the equivlent length and to multiply it with the friction rate (which is assumed constant through the entire duct length). However, with another calcultion, the friction rate is determined for the varying sizes of the duct. I am confused between the two.
    Any suggestion?
    I appreciate an example in FPS unit!
    Nevin.
    Oct 2001
    Nottingham UK
    5,127
    42
    Mar 2008
    219
    14
    Re: Duct losses determination
    For a simple to understand guide Google "Woods Guide to Fan Engineering" you can download the book as a PDF file and print it if you prefer.
    Location, United Kingdom
