    berti's Avatar
    berti Guest
    evaporative condenser coil design calculation
    I have an project to design evaporative condenser.Design Conditions are:
    Fluid:R404A
    Condensing temp.:38 C
    Wet Bulb Temp:26 C
    Requested Capacity:210 Kw
    Tube :26,9mmx2,6mm thickness of galvanised carbon steel
    Can you help me about the sizing of the coils?
    11,025
    Re: evaporative condenser coil design calculation
    You would normally use circulating water in an evaporative condenser, with a shell and tube or plate heat exchanger on the chiller.
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, berti
    Quote Originally Posted by berti View Post
    Fluid:R404A
    Wet Bulb Temp:26 C
    please check those links ...
    https://www.ideals.illinois.edu/bits...9750/TR048.pdf
    http://www.achrnews.com/articles/sizing-and-selecting-evaporative-condensers
    http://www.engineeringtoolbox.com/heat-condenser-evaporator-d_881.html#.UpDsfuJ9XTs
    http://apps1.eere.energy.gov/buildings/publications/pdfs/building_america/measure_guide_evap_condensers.pdf
    http://fire.nist.gov/bfrlpubs/fire00/PDF/f00074.pdf
    http://www.ecw.org/prod/335-1.pdf
    http://ewkformersulzer.com/ingles/Productos/catalogos/Condensadores%C9vaporativo_IN.pdf
    http://www.google.hr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&ved=0CFEQFjAD&url=http%3A%2F%2Fwww.conftool.com%2F2012Purdue%2Findex.php%2FHermes-2012-Thermodynamic_Design_of_Condensers_and_Evaporators-2100.pdf%3Fpage%3DdownloadPaper%26filename%3DHermes-2012-Thermodynamic_Design_of_Condensers_and_Evaporators-2100.pdf%26form_id%3D2100%26form_version%3Dfinal&ei=J-6QUrXJPMLItQa9hYC4Aw&authuser=1&usg=AFQjCNHmpF0WuQmIlGxylm7XWHDSmqfhFQ&sig2=Wl86LwVZKmmzWAaatQBPdQ&bvm=bv.56988011,bs.1,d.bGE
    http://lms.i-know.com/pluginfile.php...0Condenser.pdf
    and the last and good one ...
    http://www.gobookee.org/evaporative-...n-calculation/
    Hope this will be of some help to you.
    Best regards, Josip
