    Jul 2012
    Australia
    57
    61
    12
    Leak detection dye
    Wondering about using dye in system to find leaks - does anyone use it and has it been successful in finding difficult leaks
    Mar 2006
    newcastle upon tyne
    Re: Leak detection dye
    Used it does work but just buy a good leak seeker and a bottle of ofn!
    May 2012
    59
    1,528
    36
    Quote Originally Posted by RBM View Post
    It depends on the system and it depends on why you can't
    find the leak using normal leak detection methods.
    You need to ask yourself why the manufacturers don't put
    it into a new system?
    If it was meant to be in there, they would put it in. The only
    stuff that should be in a fridge is refrigerant and oil (and we
    tolerate oil only because the compressor needs it).
    All leaks can be found with bubbly water and a good leak detector.
    If you are struggling to find a very small leak, then use a blend
    of OFN and Helium to find the small hole.
    From experience I have found that large leaks tend to be made up of
    smaller leaks and you have to find them all, systematically one after
    the other. If you can't find the one big leak, then look for lots of small ones.
    Rob
    Jan 2006
    Croatia
    68
    2,263
    31
    Rob
    Nice answer Rob,
    unfortunately, to make a profit at all costs, nowadays chemical industry use to offer some "shortcuts",
    in my opinion it is the same like teaching us how to be stupid.
    Best regards, Josip
