Thread: Technical problem
18-11-2013, 08:48 AM #1
Technical problem
if i totally filled my chest freezer with sachet water the compressor sometimes stop after working for some hours but if partially filled it doesn't behave like that.
what can be the cause of that?
18-11-2013, 12:15 PM #2
Re: Technical problem
You are probably putting in more heat energy than the compressor can deal with so it overheats and shuts down on safeties....but then again, without more information, I am just guessing.
18-11-2013, 08:26 PM #3
is there a fast freeze switch??- if so this will override the thermostat, if it still cuts out, as frank says klixon/overheat
20-11-2013, 08:42 PM #4
21-11-2013, 09:20 AM #5
Hi, all ... what a mighty internet ....
nice, but useless in this thread .... unfortunately...
IM very good Q .... and above knowledge is coming from here ....
http://energy.gov/energysaver/articl...ioner-problems
or maybe from here .... http://www.daviddarling.info/encyclo...nditioner.html
or from here ..... https://www.facebook.com/xtremecoldair/posts/414358118589391
there are much more pages with the same sentence as above ....
Best regards, Josip
23-11-2013, 12:02 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
These are most likely automatically generated answers from some "bot"!
I think that need Webram attention!
Same thing happening on local forum where I participating. Lot of posts/comments like that (1000 and more daily) and server load at Godady is high with lot of "service unavailable" messages because of that.Last edited by nike123; 23-11-2013 at 12:24 PM.
